Points Out - Lists Out
age of sigmar
7 replies to this topic
#1 dwarfsarethebestaround
  • 249 posts
Posted 28 July 2016 - 07:05 PM
So,
I'm wondering what you guys think would work well for a 1000 point game, using the new points system from the General's Handbook. It's quite annoying how the only Battleline units are the Warriors and Longbeards, as I think they should go along with the 'core' theme from Fantasy, which should mean Quarrellers and Thunderers being Battleline as well, but oh well.
This is my first attempt at making a reasonably competitive list. What do you think works and what doesn't? And generally what lists do you think work? Any input is welcome!
Dwarf Lord Shieldbearers - 160
BsB Thane - 80
Thorek Ironbrow - 140
Kraggi - 20
30 Warriors - 300
20 Longbeards - 280
Total: 980
#2 sgreg308
sgreg308
  • 1,015 posts
Posted 29 July 2016 - 03:32 PM
It could work well, but i'm fond of finding a way to work in Bugman and his rangers with enough quarellers to get the double shot bonus. The tactical advantage of deploying rangers nearly anywhere at anytime on the battlefield gives you, is amazing. You are able to sandwich tough foes and tilt unfavorable combats last minute with little effort using them and without mobility, enemy armies will simply run around you or shoot you from afar.
#3 Bimli
Bimli
  • 980 posts
Posted 29 July 2016 - 05:24 PM
I think you need some shooting as with some armies you wont make it across the field. The storm cast for example have a ton of shooting that will pick away at you until your to small to be able to fight back. Also the issue with thorek is I think he is to easy to pick off with artillery.
Bugman + rangers is a must IMO.
Edited by Bimli, 29 July 2016 - 05:25 PM.
#4 dwarfsarethebestaround
  • 249 posts
Posted 29 July 2016 - 05:36 PM
Yes - the Bugman and rangers combo is great, and I hadn't properly considered using them that way. Another list with these added units;
Bugman - 100
Ungrim - 100
Runelord - 80
20 Warriors - 200
20 Quarrellers - 240
20 Longbeards - 280
#5 Lesti Ardisson
Lesti Ardisson
  • 125 posts
Posted 29 July 2016 - 06:04 PM
The Longbeards are a great buff unit. But I wouldnt field more than 10 of them. Beardy I would Even set them up as a thin line to spread the wound buff. ;)
So less longbeards.
Also You are missing the 60 points for the grudgebound or disposessed throng.
Reroll hits of 1 and no fleeing dwarfs on a 1-3.
And with the generall ability from the generals handbook You can reroll Any battleshock test.
Imo making the Thane obsolete.
#6 Bimli
Bimli
  • 980 posts
I would take out 1 unit of warriors and 1 unit of long beards so make them 10 strong each then add another 20 man quarrelers unit
#7 dwarfsarethebestaround
  • 249 posts
Posted 29 July 2016 - 06:26 PM
The frustrating thing with the points system is that the only battleline units are warriors and longbeards, so If I'm gonna take them, then I feel I should make a good unit rather than pretty much throwing them away. I'm not sure I can fit a Dispossessed Clan Throng in there :unsure:  The 1000 points now doesn't seem like a lot...
#8 Bimli
Bimli
  • 980 posts
Posted 29 July 2016 - 07:54 PM
for 1000 points you can take the dispossessed clan throng it just is not that good sadly.
Edited by Bimli, 29 July 2016 - 07:59 PM.
Also tagged with one or more of these keywords: age of sigmar
