Hey guys!
I have spent the last 4 hours creating the first section of my custom made Karak Eight Peaks campaign, although i have only made the first scenario, I will mark the title as updated when I will create the second one and will add a I every time I write a new section after that point, whenever I do this I will also deleted the link to word a update it with the knew stuff.
I have made it as concise as possible, just a note, the Skaven betrayal table only comes into effect when Queek Headtaker makes an appearance so don't worry about it for now.
The prefix of the campaign is that Belegar Ironhammer is trying to retake Karag Nar (One of the Eight Peaks) as waaagh! Skarsnik has just been launched against the Skaven and as his two enemies fight it out Belegar sees an opportunity to reclaim an entire section of his hold. I decided that this would be a much more plausible idea then Belegar trying to re-tack the entire hold at once; due to the fact that tacking back an entire Peak is no small feat and I imagine that with the resources at Belegars disposal it would be a great victory but a realistic goal. I chose Karag Nar as the Peak which Belegar is trying to reclaim because it is the closest to the citadel (both mountains are actually connected), and would make trading with Karak Azul slightly easier.
Finally I also urge people to try and play test this if they can to give me good advice, I will try play testing it too, albeit using proxy's as the orcs and Goblins and Skaven. I do own the army books for both factions so I was using it when creating the units for the armies in the scenarios.
Here is the link. Enjoy!
https://docs.google....1-DPeUM7WU/edit
(By Grungni's Beard I preferred word where I could use text boxes)
Edited by Hero of Rome, 22 June 2016 - 04:56 PM.
