Aos - Organ Gun Rules (How To Play) Clarification.
age of sigmar organ gun rules
7 replies to this topic
#1 Grimblaze
Grimblaze
  • 24 posts
Posted 11 August 2015 - 11:58 AM
Hey all, hope you don't mind, I just wanted to clarify if I understood the new Age of Sigmar rule for the organ gun.
Assuming that I have a 3 crew and I want to fire 4 barrels, the process is:
1) Roll for cannon misfire
  -  number of barrels+   [so a 4+ on a D6]
  -  This can be re-rolled if an engineer is in 1 inch
2) Roll for hit for each barrel based on chart
  -  with three crew this is a 3+ on a D6 (x4 - for each barrel).
3) For each successful hit, roll a D6 for wounds.
With 1 crew member firing 4 barrels, this is a 4+ misfire roll and a 5+ to hit for each barrel.
Sorry if this is obvious, just wanted to check I had understood the rules correctly.
Thanks
Edited by Grimblaze, 11 August 2015 - 12:04 PM.
#2 Young 'Un
  • 11 posts
Posted 11 August 2015 - 12:07 PM
You make 1d6 hit rolls for 1 damage each, per loaded barrel.
#3 Stuntieboy
Stuntieboy
  • 23 posts
Posted 11 August 2015 - 12:51 PM
I haven't played AOS yet, as I've only just returned to the hobby. But my understanding from the rules is:
1. Roll for misfire as you said
2. Roll one die per barrel for the total number of shots
3. Roll to hit and wound for each shot (3+ for both if all the crew are still alive) and work out wounds as normal.
#4 Grimblaze
Grimblaze
  • 24 posts
Posted 11 August 2015 - 01:02 PM
Ah, that makes more sense - so figure out the number of attacks and each attack is a dice roll of 3+, 4+ or 5+ depending on crew number - so we still get to roll a load of dice  :cool:
Cheers
#5 Bimli
Bimli
  • 980 posts
Posted 11 August 2015 - 11:06 PM
sadly the OG has become our weakest war machine sad times indeed :(
#6 Pm713
Pm713
  • 62 posts
Posted 11 August 2015 - 11:39 PM
What about the Bolt thrower? The Organ gun seems like it could be good against low armour units with large numbers.
#7 Weezheat
Weezheat
  • 135 posts
Posted 11 August 2015 - 11:43 PM
I don't think it's the weakest. It's just more random than ever. I usually load 3 barrels with an engineer and haven't had it jam almost ever.
There have been times that I get 5 shots and they all mis, but I've also had it do 15 shots with 12 wounds.
It's random but can destroy face too.
#8 Bimli
Bimli
  • 980 posts
Posted 12 August 2015 - 11:52 PM
the bolt thrower is actually not so bad it has good range can due huge damage and shoots 2 times
the organ gun has a chance of not shooting this is bad i think. you'll probably be rolling 3 dice 9 times out of 10 so on average your looking at 10/11 hits needing 3's and 3's - so with 11 hits your looking at 5 wounds with rend of 1
I say its our weakest cause if you think about it, what would you take it over via our other warmachines.... maybe the bolt thrower.... but other than that?
Also tagged with one or more of these keywords: age of sigmar, organ gun, rules
