On the old dwarf armybook I used to have only one runepriest hidden behind a rock popping runes of dispell whenever a dangerous spell went out, but in the new edition you need at least 2 runepriest for the same effect, besides you have the armourpiercing rule which is given to any infantry unit the runpriest or runelord joins and on another note, what happens with units of Thunderers or Quarrelers when a runepriest/lord joins them, does the melee weapon get the armour piercing? or the long range weapon? or both? the armybook does not specify it is exclusive for either. This would change some of my gameplay drastically.
7 replies to this topic
Posted 10 August 2014 - 03:27 PM
Posted 10 August 2014 - 03:41 PM
BRB pg 67 "Wounds caused in CC by a model with this special rule". Any RS/RL giving the Armour Piercing special rule does so in this way. The only way for a ranged weapon to have AP, is if the weapon itself sates it has AP in it's own specific Special Rules.
As for the title of the thread. Kind of a cheap way for GW to say, "Hey, I know your spending 200+ pts just to to not participate in magic, so here's AP, enjoy!". You want 1-2 RS in your army just to manage magic phases, so the bonus AP is nice. And against high AS opponents it's very nice. This with the +1S on charge makes GW warriors do some dmg to even the best AS opponent. Overall I'd say it's very nice to have, especially with the Firey Ring of Thori or Silver horn Combos, Runesmiths have some versatility and it almost makes you forget your spending a good deal of pts just to stop magic, when other Armies spend the same pts for lvl3-4s who have better dispell and can cast as well.
Posted 10 August 2014 - 03:57 PM
Yep a nice bonus to have especially on shieldbeards / ironbreakers as it helps make them that little bit more choppy. Also don't forget runesmiths also give the unit MR.
Guest_Mountain_*
Posted 10 August 2014 - 04:17 PM
Can runesmith/runelord MR combined with RoSan or not?
Posted 10 August 2014 - 05:39 PM
Thanks for the clarification man, I'll have to tweek my list a bit then!
Posted 10 August 2014 - 06:34 PM
<br />I belive it can. So a rs in a unit with sanct gives that unit mr 2.<br />I do hope mr changes in 9th editionCan runesmith/runelord MR combined with RoSan or not?
Posted 10 August 2014 - 08:23 PM
You use the highest MR from one souces in a unit. DOn't have my BRB or AB with me right now, but I believe it is worded in a way to make that BRB ruling stick. So if you have a RP in a unit with one Ro Sanctuary, they have MR1.
#8
Posted 10 August 2014 - 08:24 PM
You dont add them up, you only take the best.
Also tagged with one or more of these keywords: rune, priest, lord, runpriest, runelord, armourpiercing, armour, piercing, worth
The Great Hall →
The Main Fireplace →
Master Rune Of GrimnirStarted by mikex , 04 May 2021 ![]() |
The Great Hall →
The Forge →
Quick 'n' Dirty Lamellar Armour Sculpting TutorialStarted by Karak Norn Clansman , 05 Sep 2017 ![]() |
The Great Hall →
The Forge →
Adding RunesStarted by evendel , 03 May 2016 ![]() |
The Great Hall →
The Dwarf Tavern (9th Age + 8th Ed Warhammer) →
Can You Use A Spellbreaker Rune After Rolling To Dispel ?Started by Rolf , 23 Mar 2015 ![]() |
The Great Hall →
Should I Bring A Tank Lord In This List?Started by dwarfsarethebestaround , 02 Feb 2015 ![]() |
