Some Unit Fillers
unit fillers
17 replies to this topic
#1 Thorrin
Thorrin
  • 171 posts
Posted 02 May 2014 - 10:26 PM
Hello my fellow dawi. I have 16 miners but I want a unit of 20 miners, so the best way to get to a unit of 20 miners is by using a unit filler. But I lack the inspiration and ideas to make a good unit filler with an underground or miner theme. If you have any ideas, or miner unit fillers that you have made please share pictures with me or just share an idea of one so that I can begin constructing my unit filler.
Thanks
Edited by Thorrin, 02 May 2014 - 10:28 PM.
#2 Thorgrimtheunyielding
  • 330 posts
Posted 02 May 2014 - 11:31 PM
You could use the mine pony that comes with the miner set. That's what I used for mine.
#3 Swordthain
Posted 03 May 2014 - 12:54 AM
http://www.bugmansbr...-project-album/ It's not very good, but it's simple and effective. It takes up a 100x40mm space, replacing a full 10 Miners!
Edited by Swordthain, 03 May 2014 - 12:55 AM.
#4 Marauder guy
Marauder guy
  • 201 posts
Posted 03 May 2014 - 01:05 AM
Just build a simple little mine cart
#5 WI Dwarf
WI Dwarf
  • 87 posts
Posted 03 May 2014 - 01:12 AM
i always liked the miners popping out the ground models. If you have spare bits you could try that.
#6 datalink7
datalink7
  • 107 posts
Posted 03 May 2014 - 01:14 AM
Easiest thing is to take a 40mmx40mm base and make a kind of diorama with only two miners. Maybe have them killing a gobo. I've done this with zombies and ghouls and it works well (couple of ghouls chowing down on a person). This essentially turns 2 miners into 4.
#7 Wendersnaven
  • 1,874 posts
Posted 03 May 2014 - 03:19 AM
You could also go with a pony and single handler on the square base. Glue some extra gear to the pony to haul around.
#8 karakvarn
karakvarn
  • 256 posts
Posted 03 May 2014 - 07:35 AM
I have a spare drunken miner if you wanted to trade?
#9 Lord Alisk
Lord Alisk
  • 1,363 posts
Posted 03 May 2014 - 08:15 AM
|One thing I'm going to do with my miners is put the free standing drill with one dwarf operator on a 40mm base. I think that should look OK,
#10 Monk
Monk
  • 209 posts
Posted 03 May 2014 - 09:29 AM
This was done quite a while ago.  It takes up 9 spaces but also includes a spot for one miner.  Very easy, just a couple of pieces of slate, wooden ice cream sticks and some dwarf bits.
#11 Thorrin
Thorrin
  • 171 posts
Posted 04 May 2014 - 06:36 PM
Thanks guys for all the replies and inspiration once a start constructing my unit filler I'll share it.
#12 Vulcan
Vulcan
  • 317 posts
Posted 06 May 2014 - 01:15 AM
Somewhere around here is a picture of a miner unit that was still underground...
It was a bunch of empty bases fully finished with trees and stuff. Priceless... :thumbup:
#13 Giant collector
Giant collector
  • 587 posts
Posted 06 May 2014 - 05:38 PM
I'd go with a version of Monks unit filler built to your own design preference. Gc
#14 Stymie Jackson
Stymie Jackson
  • 2,555 posts
Posted 07 May 2014 - 05:57 PM
I keep mine small. Mainly for tournament points as it breaks up the look of the unit to add something unique rather than to bulk up a unit.
My hammerers have an Ogre hooker who 'escorts' them into battle. She takes up a 2x2 space:
For my warrior blocks (GW usually as they typically are run in horde formation) I have two different ones. The first is two more slayer pirates with a dragon on a 2x3 base. Pic is a little too washed out sadly:
The final one is another 2x2 small filler. My personal favorite featuring 5 time chaos cup champion, Bhudd Lightbringer. Also found a use for one of those awful BoSP plastics:
Special minis, like dwarf adventurers, slayer pirates, blood bowl minis or drunken dwarfs (there's a drunken miner you would probably want to talk a look at in the set) are excellent to use in a diorama and allows you to put in something you normally wouldn't be able to.. I still have a grudge pony to do something with...is there a friar Tuck style Dwarf anywhere?
Edited by Stymie Jackson, 07 May 2014 - 06:13 PM.
#15 TaxiForBiggins
Posted 08 May 2014 - 03:18 AM
Monk - that's a great little filler. Bonus points for the spot for the miner.
For other units, there's always the option of a statue - a 2x2 or 3x3 base podium with a warrior on top, all painted as stone. It's a bit cliche, but awesome. Why is this so awesome? I'll tell you why! Who has 20-40 quarrellers with shields, 20-40 with GW, and 20-40 'naked'? Not me! Sure you can do the usual 'fill the front rank as equiped and use generics for the other ranks', but you can instead have a variety of statues as fillers, and you can say to your opponent 'equiped as per the statue'. Done. I think statues are best made with metal minis for character, and because statues are 1-piece, like most metal minis.
#16 Wendersnaven
  • 1,874 posts
Posted 08 May 2014 - 03:41 AM
At first my reaction was ... "Awwww, I don't want my guys hauling around a statue..." but, that's a really good idea. With a little color variation (or something) you could also tell unit A from its copy B on your list.
#17 Son of Starbreaker
Son of Starbreaker
  • 73 posts
Posted 11 May 2014 - 05:45 PM
As someone else above said, the mine cart and pony would be good. You could get some ale barrels and stack then up inside it or convert a bunch of grobi as corpses to fill it up.
#18 BigSugaryDwarf
BigSugaryDwarf
  • 67 posts
Posted 15 May 2014 - 06:31 AM
A quick fix could be a stack of mining equipment. The supplies that come on the cannon sprue would work well.
Also tagged with one or more of these keywords: unit fillers
