I noticed that the new rune of luck allows rerolls to hit, to wound, armour saves, ward saves and now characteristic tests. Seeing as we seem to be a bit weaker in magic defense, does this make a rune of luck an auto-include as a kind of extra save for your general against dwellers or purple sun or other characteristic test based spells?
Posted 05 March 2014 - 08:51 AM
Posted 05 March 2014 - 09:29 AM
On a related note, here's an interesting bit from the errata that me rumaddled brain remembered:
Command Groups
Q: Does the ‘Look Out Sir’ special rule apply against all spells
that use templates? (p93)
A: Yes.
Good to know, ain't it?
Posted 05 March 2014 - 10:31 AM
I did not know that! Thankyou very much!
Posted 05 March 2014 - 10:45 AM
I suppose it depends on how often you expect to be forced into taking that kind of test, how much of a risk it is, and how you want to kit your characters otherwise. My initial thinking was that that this would be a very useful rune to counter those killer spells, especially as our magic defence has dropped.
However, I don't often find myself loosing character to those spells, and am not settled yet on whether this will change with the loss of magic defence. My characters are not usually critical or expensive, and it may be that it just isn't worth the points, or compete highly enough with the other rune combinations. I'm yet to make up my mind!
Also tagged with one or more of these keywords: rune, talisman, magic, ward
The Great Hall →
The Main Fireplace →
Warhammer Dwarf Magic The Gathering CardsStarted by Karak Norn Clansman , 04 Apr 2018 ![]() |
The Great Hall →
The Forge →
Adding RunesStarted by evendel , 03 May 2016 ![]() |
The Great Hall →
The Dwarf Tavern (9th Age + 8th Ed Warhammer) →
RunesmithStarted by Thorimo , 11 May 2015 ![]() |
The Great Hall →
Can You Use A Spellbreaker Rune After Rolling To Dispel ?Started by Rolf , 23 Mar 2015 ![]() |
The Great Hall →
Rune Of SlownessStarted by The Grim Delver , 06 Jan 2015 ![]() |
