Looking For Some Scenic Bases For My Dwarves
bases
15 replies to this topic
#1 Svaldrik Iornthunder
  • 4 posts
Posted 14 February 2014 - 08:33 PM
With the start o f my new Clan I am looking for some good scenic bases for my dwarves. I picture my dwarves retaking ancestral grounds so either ruins or or dwarf hall like stuff that I can put gravel over is what I am after. I did some searching but came up empty handed. I found a few things but not in the right size. Does anyone have any suggestions?
#2 ardyer
ardyer
  • 202 posts
Posted 14 February 2014 - 11:31 PM
Dragon forge designs has done really nice bases.
#3 dutchy1982
dutchy1982
  • 2 posts
Posted 14 February 2014 - 11:52 PM
I use scibor miniatures dwarf ruin bases. They really are top notch
Sent from my Nexus 4 using Tapatalk
#4 dutchy1982
dutchy1982
  • 2 posts
Posted 14 February 2014 - 11:55 PM
http://sciborminiatu...hop.php?art=648
Alternatively
http://sciborminiatu...op.php?art=1309
Edited by dutchy1982, 15 February 2014 - 12:01 AM.
#5 Sanza
Sanza
  • 217 posts
Posted 15 February 2014 - 04:46 AM
Look at this :
http://www.dakkadakk...ing_Resin_Bases
#6 Skull Krusher
Skull Krusher
    Skazastoki
  • 2,547 posts
Posted 15 February 2014 - 05:39 AM
makes a bunch of bases you like... make molds of them... cast them in resin.... molds material is cheap but not the two part resin...
#7 Drakkol
Drakkol
  • 410 posts
Posted 16 February 2014 - 12:21 PM
I have made a new set of Bases. For me. Bases and movement tray ... If you're still interested I'll upload a pic.
Edited by Drakkol, 16 February 2014 - 12:22 PM.
#8 That Hardy Boy
That Hardy Boy
  • 49 posts
Posted 16 February 2014 - 12:35 PM
http://www.dragonfor...tasy/temple.htm
Temple bases from Dragon Forge!
#9 Drakkol
Drakkol
  • 410 posts
Posted 16 February 2014 - 03:08 PM
http://www.bugmansbr...-dwarves-tiles/
#10 Ulfgar Stormhammer
Ulfgar Stormhammer
  • 13 posts
Posted 16 February 2014 - 04:06 PM
If you're willing to put some time into it, a Dremel tool and some wood can make amazing things.  :smiling:
#11 Skull Krusher
Skull Krusher
    Skazastoki
  • 2,547 posts
Posted 16 February 2014 - 05:07 PM
How did you do this... and is there a template that you trace out the design?
#12 Drakkol
Drakkol
  • 410 posts
Posted 16 February 2014 - 05:19 PM
I did a "freehand drawing ", cut, took a negative and made a positive. ;-)
Simple and effective. If someone, lazy enough, wants resin copies... PM me O:-)
#13 dazza36
dazza36
  • 1,123 posts
Posted 16 February 2014 - 05:29 PM
Probably an easier way would be to use modelling clay (the stuff you bake in oven) Anyway roll out to right size thickness and then draw design on and just carve out.
#14 Wendersnaven
  • 1,875 posts
Posted 16 February 2014 - 06:13 PM
So far, I haven't found any of these scenics that are magnetized.
Am is missing seeing them?
#15 Drakkol
Drakkol
  • 410 posts
Posted 16 February 2014 - 06:19 PM
Mine Will be wendersnaven. ;-)
Dazza... Yep but... Not if you want to have both bases and movement base with the same decoration.
Edited by Drakkol, 16 February 2014 - 06:20 PM.
#16 Wendersnaven
  • 1,875 posts
Posted 16 February 2014 - 06:35 PM
Sweetness.  I'm going to get some pics tonight of a failed plan I had.  I tried putting cobblestones down, but they were too round/bumpy and my hammerers kept breaking off of them. Since I didn't want them all at static slotta angles, I cut the tabs.  The idea I have is ... unique ... but if you are making magnetic scenics, I'll share the idea with you.
I'll shoot you a P.M. in a few. Just need to get to my stuff and take pics.
Also tagged with one or more of these keywords: bases
