Warhammer Bases, Alas
josef bugman bases large
11 replies to this topic
#1 Thorgrimtheunyielding
  • 330 posts
Posted 30 June 2012 - 09:18 PM
I have recently purchases the Josef Bugman model, the one where he stands proudly on two barrels of Bugman's XXXXXX. I want to make him lead a squad of great axes, to recreate Bugman's Rangers, but unfortunatley, his base is to big. Even a cavarly base want fit perfectly in the unit. What do you recommend?
#2 Monk
Monk
  • 209 posts
Posted 30 June 2012 - 09:34 PM
My local craft store sells some MDF in the form of a coaster, (for under a beer in a bar). They are blanks, designed to be painted however you want. I cut them down to the base size I need and they are the same thickness as all my bases. Check out my gallery for artillery pieces (full sized coaster) and various unit fillers that are 2, 6 and even 9 bases in size.
#3 whatawittyname
whatawittyname
  • 214 posts
Posted 30 June 2012 - 09:49 PM
The best thing to do it stick two 20mm bases together on a piece of thin balsa or plasticard, then fill the gap with green stuff.
Very easy and the ideal size.
#4 Bonecrusher
Bonecrusher
    Kro'undi
  • 5,837 posts
Posted 03 July 2012 - 09:04 AM
Either use two 20x20 bases, or if you want a more dramatic scene you could use a 40x40 base, though he would also count as rangers as well you'd have to note.
#5 Thorer Fireforge
Thorer Fireforge
  • Banned
  • 501 posts
Posted 03 July 2012 - 01:30 PM
I just use my as a unit filler
#6 Alaric Ironaxe
Alaric Ironaxe
  • 4,461 posts
Posted 03 July 2012 - 02:18 PM
2 20mm bases is probaly the best way to go, would fit in with the unit well.
#7 Sanza
Sanza
  • 217 posts
Posted 24 July 2012 - 10:51 AM
Does anyone know where I can buy war hammer bases, simple, 20x20, with the hole in diagonal and bases with the hole parallel to the edges ?
I got 20 Zweihänders from WK, but I don't have any base left :(
Thanks in advance folks !
S
#8 Alebelly_Cragfist
Alebelly_Cragfist
    Dwarf Of Legend
  • 7,346 posts
Posted 24 July 2012 - 11:28 AM
GW sell them, or there's a number of other eTailers that will. GW ones too pricey?
#9 Thane Morgran
Thane Morgran
  • 524 posts
Posted 24 July 2012 - 11:56 AM
GaleForce 9 do some bases that are magnets (not rare earth ones I believe, but the size ought to make up for it). Same price as GW's....
#10 Darkblade
Darkblade
  • 2,484 posts
Posted 24 July 2012 - 12:48 PM
I used a 40 x 40 for mine....
If you position the barrels toward the front then theres' plenty of room for 2 R & F to stand behind or you can position the barrels in the middle to use it as a filler.
#11 Bonecrusher
Bonecrusher
    Kro'undi
  • 5,837 posts
Posted 30 July 2012 - 07:18 AM
Darkblade, in that picture those bases are 20x20, and the 40x 20.
But to the original question GW sell them diagonally and horizontal slots.
#12 Darkblade
Darkblade
  • 2,484 posts
Posted 30 July 2012 - 08:33 PM
Sorry I thought thorgrimtheunyielding needed advice on using 2 20 x 20s or bigger, my mistake I suppose.
Also tagged with one or more of these keywords: josef, bugman, bases, large
